vcPlaneFeature
The plane feature generates a planar geometry. It is typically used as a reference geometry for other operations such as sketching lines. It is also used as a parameter to the Slice operation.
Module: vcFeatures
Parent: vcFeature
SizevcRealExpressionPropertyR
Access expression value via vcRealExpressionProperty
Gets or sets the length and width of the plane.
